ceedubya
crazy legs
Mar 18, 2004
130
newcastle upon tyne
i have read a few treads where people have added a inline fuel pump while adding a bigger turbo
my spec will be = bam engine, bam fuel pump, 3 bar fpr, uprated rods, td05/18g (16g originally modified to 18g) 550cc bosch injectors
i would "like" to see 350 bhp/lbft safely:whistle:
i can get a brand new 190 lph inline bosch pump that i could fit if needed
do i need to add this pump or a bigger one or will my bam pump work ok ???
BAM pump *should* cope, BUT it will be running at its limit so any wear and tear or voltage drop at the pump will likely risk "lean" moment.......... which is terminal for your pistons & valves in my personal experience.
do you want to risk it, or build in some safety margin?
I know what I would do.
I would fit one for sure. Is the bosch pump you mention from a K-jetronic volkwagen or similar?
Im running 550cc injectors, std intank pump and a walbro 225 lph inline pump. Pushed 360bhp easy before it was finally mapped. Now its mapped its much stronger and the timing could be increased too. I would deffo add the inline pump. We can do one with wiring kit for £175 + Vat.
i best get it fitted then, i want to be safe not sorry:doh:
the pump is a brand new item originally meant for a rs turbo = PART NO.0580 254 910
from the info i can find its rated at 190 lph
will this pump be ok or do i need 225lph plus
thanks for your help/tips:cheers:
What injectors are you running? You need to work out the flow they require. This is at 100% duty.
Eg, 630cc/min injectors x 4 = 2520cc/min / 1000 x 60 = 151.2l/h flow
You then have to factor in your fuel pressure and the max boost you will run.
Eg, 3bar is 43.5psi + say 25psi boost = 68.5
Now you need to compare that with the flow chart of the pump you want to use if you have it. This is a walbro one for example.
So thats 132l/h flow, or 158.4l/h if you add a 20% overhead for safety and 65.26psi.
You need to find the flow chart for that pump if you can.
upto 500bhp we use walbro 255l/h hardwired ,after this we put a inline bosch 044 pump with the walbro being a lifter pump,good for at least 600bhp
i am aiming for around 350 lb/ft with similar bhp on my td05/18g with 550cc injectors
do you think my oem 225bhp TT pump along with a bosch 190lph inline pump be a safe option ?
or do i need a higher output inline pump:confused:
i wont be looking for more power on this car in the future, just a reliable daily set up
Chris,
I spotted this graph for your intended pump. Comparing the values of 132l/h (2.2l/m) at 65.26psi (4.5bar) to the graph you can see that it falls under the max flow of 162l/h (2.7l/m) at your max intended boost. This will give you an 18.5% overhead which I think is acceptable.
As far as I can tell you should be fine with this pump.
There are also graphs for other bosch pumps here if people are interested.
