Help k04
adamkirk160
8
Hi need some advice
Did a k04 swap onto my ibiza and having a problem with boosting seems like it's in limp mode but no codes or lights come up. I got the turbo off a running bam everything seem fine had it checked by a local turbo supplier. I've done boost leak testing, replaced the n75 with a new one got a new maf for a bam, all vacuum pipes got replaced. Bigger injectors fuel pump and pressure regulator as well.
Any advice or links to similar threads would be a hung help would like to be on the road in April.
Thanks in advice
