antnee
Looking to get a pressure washer, but dont want to spend loads on one something like 50quid if its possible
links would be nice
links would be nice
Couldn't agree more, pressure washers have a role in shifting caked on mud under wheel arches or cleaning block-paved drives but treat the bodywork gently - a sheepskin mitt is even kinder than the good old sponge. I was actually advised by SEAT Wolverhampton a while ago to not use a pressure washer as it can lead to the CupraR badge getting infiltrated and eventually totally discoloured - they did replace them F.O.C. and I've moved onto a K1 which is pampered and has never seen the pressure washer !STIHL RE270K HIGH-PRESSURE WASHER is what I use, very powerful...bit too powerful to be hones!
So much so I deliberately removed all the paint work from my mountain bike using it, saved me hours instead of sanding! I always use the foam attachment and spray from a distance to avoid jetting water in places it shouldn't be, like the headlamps.
I think handwashing is the best way to clean a car, pressure washers are a bit crude, they just spread the dirt about rather than totally remove it.
they are good for tyres wheel arches and underneath the car/ rinsing, but for a real clean finish, get your bucket and sponge out!
