What pressure washer
antnee
Looking to get a pressure washer, but dont want to spend loads on one something like 50quid if its possible
links would be nice :D
Dec 13, 2006
724
Ashford, Middx
Saying that, i bought a karcher last week from tescos and the water was leakin from the gun so was losing loads of pressure. Took it back though and bought a karcher k2.87 worked out £55 i think.
Will give it a go in abit and see if its any better.
Dec 13, 2006
724
Ashford, Middx
Had a go with the karcher k2.87 today. Firstly the gun didnt leak so no pressure lost which was a good start.
As far as a budget pressure washer i think it does the job. The hose is longer than the pressure washer i had before so saved me carrying it every 2minutes. I'd recommend it if your on a budget.
rye#1
80
sunny barnsley
karcher are a good brand and motors.also you can get a mac from bnq wich are strong motors and a bit cheaper and foam lances are available.
JD_SCN
STIHL RE270K HIGH-PRESSURE WASHER is what I use, very powerful...bit too powerful to be hones!
So much so I deliberately removed all the paint work from my mountain bike using it, saved me hours instead of sanding! I always use the foam attachment and spray from a distance to avoid jetting water in places it shouldn't be, like the headlamps.
I think handwashing is the best way to clean a car, pressure washers are a bit crude, they just spread the dirt about rather than totally remove it.
they are good for tyres wheel arches and underneath the car/ rinsing, but for a real clean finish, get your bucket and sponge out!
antnee
I got a karcher 2.78 (something like that) the 55quid one from tesco. Only had a quick play with it last night but it seems good, quiet but still powerful, without loads of sprayback!
antnee
Did you read the thread? Ive already bought one. If it breaks I will take it back
Lance
Couldn't agree more, pressure washers have a role in shifting caked on mud under wheel arches or cleaning block-paved drives but treat the bodywork gently - a sheepskin mitt is even kinder than the good old sponge. I was actually advised by SEAT Wolverhampton a while ago to not use a pressure washer as it can lead to the CupraR badge getting infiltrated and eventually totally discoloured - they did replace them F.O.C. and I've moved onto a K1 which is pampered and has never seen the pressure washer !
Dec 13, 2006
724
Ashford, Middx
Dont mean to be rudelance but i dont think SEAT will have as much cleaning knowledge as people on DW.
I use my pressue washer to rinse the car and then use it with my foam lance which breaks down the dirt nicely before i wash it.
As for using a sponge, i dont think that is a very good idea. Can cause alot of damage using one of them. Each to teir own i suppose though.
Lance
http://direct.tesco.com/q/R.100-9669.aspx
whats your thought on this washer, good buy or not?
Can't really comment on the jetwasher on special offer, but I thought an illuminating feature on 5rh Gear might be worth this forum listening to - nothing radical but perhaps a surprising outcome of their test and a reminder to be careful ! Whichever way you wash your car Mr Grit is always waiting !
http://fifthgear.five.tv/jsp/5gmain.jsp?mnk=410&id=335&description=Car-washes
