DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Done Some logs tonight with curzon to make sure its all heathy and if theres any room for improvment..
My mods Are:
Custom jabbasport map
4 bar
Atp Manifold
3'' downpipe and De-cat
2.5 cat milltek system
forge tip
Fmic
Uprated Fmic pipe work (68mm)
k03s
320bhp jetex filter
007p with Yellow spring
Egr/Sai Removal
n112 and N249 Removal
99ron+ fuel
Curzon will post the logs up as i don't now how todo them.
Code:
	Group A:	'020				Group B:	'002
		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Inj. On Time	Mass Flow
	TIME					TIME
MARKER	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	%	 ms	 g/s
	0.01	0	0	0	0	0.4	2240	47.4	10.25	35.58
	0.8	0	0	0	0	1.2	2480	121.1	17.63	64.94
	1.6	0	0	0	0	2	2800	169.9	24.6	95.67
	2.4	0	0	0	0	2.8	3200	179.7	25.83	106.86
	3.2	0	0	0	0	3.61	3600	177.4	25.42	119.61
	4.01	0	0	0	0	4.4	4040	179.7	25.83	140.11
	4.81	0	0	0	0	5.31	4480	182.7	25.83	155.17
	5.71	0	0	0	0	6.11	4880	178.2	25.42	164.64
	6.6	0	0	0	0	7	5240	170.7	25.01	171.03
	7.4	0	0	0	0	7.8	5560	160.2	24.19	169.75
	8.2	0	0	0	0	8.6	5840	154.9	23.37	171.78
	9	0	0	0	0	9.4	6080	150.4	22.96	175
	9.8	0	0	0	0	10.2	6320	145.1	22.14	175.81
	10.6	0	0	0	0	11.02	6480	141.4	21.32	175.58
	11.4	0	0	0	0	11.8	6640	126.3	15.58	161.83
	12.2	0	0	0	0	12.6	6520	6.8	0	7.78
Code:
	Group A:	'115				Group B:	'118
		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar
	0.4	2520	41.4	1000	1060	0.01	2480	15	0	1060
	1.2	2680	129.3	2210	1550	0.8	2560	14	83.1	1150
	2	3040	173.7	2330	2250	1.6	2840	12	76.9	2000
	2.8	3480	186.5	2320	2380	2.4	3280	12	79.2	2330
	3.6	3920	185.7	2350	2340	3.2	3680	12	79.6	2350
	4.4	4320	184.2	2320	2310	4	4120	12	81.2	2310
	5.2	4720	179.7	2200	2220	4.81	4520	14	83.5	2270
	6	5080	175.2	2050	2130	5.6	4880	15	84.7	2180
	6.89	5400	164.7	2000	2030	6.4	5240	17	85.5	2090
	7.69	5720	157.9	1980	1980	7.29	5560	18	86.7	2000
	8.49	5960	152.6	1880	1910	8.09	5840	19	87.1	1940
	9.29	6200	147.4	1840	1860	8.89	6080	21	85.9	1890
	10.2	6440	142.1	1800	1850	9.8	6320	21	84.3	1850
	11.32	6600	139.1	1780	1850	10.6	6520	22	82	1850
	12.19	5080	91	2030	1000	11.8	6200	20	0	1310
Code:
	Group A:	'002
	TIME
MARKER	STAMP	 /min	%	 ms	 g/s
	4.67	3720	175.9	25.01	122.36
	5.09	3920	178.9	25.42	134.06
	5.47	4120	178.9	25.42	140
	5.87	4280	182	25.83	150.22
	6.27	4520	179.7	25.42	151.17
	6.78	4720	178.9	25.42	161.81
	7.18	4920	176.7	25.42	164.86
	7.58	5080	175.2	25.01	169.17
	7.98	5240	169.9	25.01	168.53
	8.38	5400	165.4	24.6	169.19
	8.78	5560	160.2	24.19	169.36
	9.17	5680	157.1	23.78	170.03
	9.57	5840	155.6	23.37	171.78
	9.98	5920	152.6	22.96	172.47
	10.39	6040	150.4	22.96	173.22
	10.77	6160	148.1	22.55	172.94
	11.17	6240	145.9	22.14	173.22
	11.57	6360	144.4	21.73	173.22
	11.97	6440	142.9	21.73	176.19
	12.37	6520	140.6	21.32	174.33
	12.77	6600	137.6	20.5	173.81
	13.17	6640	125.6	15.58	156.89
	13.57	6600	42.1	4.92	41.14
Everything looks A - OK to me.
No timing pull what so ever, im sure ive heard of jabba using the like of lemmwinks to dial in more timing, could be worth a go.
I said open the wastegate slightly and maybe more timming but with it being so cold it could be why theres no cf's
Will do them logs next time but with the snow at the min and dannys driving def a no no!
The cause of no CF`s could be down to the cold weather yeh, so crank it up and turn it back down when (If) it gets warmer ;)
I adjusted the wastegate tonight by just 2 threads and mid range defo feels more alive...
I got bored of the k03s so just bought a GTX2 turbo kits will it be alright to run it for a little while on my jabbasport map? Just dont add the 225 injectors and 3'' maf?
thanks
reduce the boost & restrict your RPM considerably.
You don't want to saturate your MAF, or max out the injectors.
Better off saving up for the map and getting it done, then just drive to the mappers and swap injectors & maf there.
check before you fit it that people will map it though... properly
How much did the gt2x turbo kit cost you if you dont mind me asking? Been think about KO3s upgrade but getting mixed reviews as to its validity as a worth wjile upgrade so may go down this route
I got the gt2x for roughtly the same price from a good mate of a k03s lol
yeah i was thinking of fitting the gtx2 and selling all my map,k03s and new tip and just wide the actutor right out so it doesnt boost..
It isnt a daily drive anyway so could i put a Oem Non mapped ecu and drive it to the mappers then add the injectors and maf like you said?
P-Torque might do the mapping, so long as you are doing all the fitting
yeah all i have to fit is the turbo
and leave everything off like injectors and maf till its mapped...
ive just email Motechperformance,Jabbasport and Rs tunings See what they say..
when I spoke to JS, they said no straight away
