Tagsy87
153
Central Scotland
hey checked the search but doesnt answer my question really, i want to lower my LCR but keep the handling good, i dont really drive fast;) but the road i drive in the morning is scary so need a bit of grip on corners, wanting to spend around 600 or 700 in the new year whats the best idea for my money?
oh and where can i get black headlight covers?
AmD have got a deal on coilovers at the moment, add to that uprated ARB's and should be your budget with much improved handling - set of 10mm spacers on the rear are meant to help as well :)
Dont forget to factor in fitting costs and alignent check.If you want better handling id look at good ARB'S front and rear first before lowering it.Lowering a car doesnt always mean it will handle better.The roll bars make such a difference to the LCR though.:)
Do you want to lower the car or get better handling as per the title?
If it's handling rather than cosmetic / aesthetic mod's then start with a pair of Neuspeed Anti-roll bars, fits inside your budget and helps handling more than any other mod I can think of
Just lowering won;t help handling as much, particularly on that budget
AmD offer is something around £435 mark for AP coilovers - including fitting and 4 wheel alignment - http://www.seatcupra.net/forums/showthread.php?t=195519
ARB's would be a better starting point in terms of handling :)
to be really honest its a bit of both i have always felt the LCR sits around 35mm too high all round but the handling isnt as sharp as i would have thought
