neilmac
Just starting to tweak...
Jul 12, 2006
294
cold weather seems to have bought on a slight creak/rubbing noise from the rear suspension as I go over speed bumps....anyone have/had this? Is it the rear bushes or possibly something else?
It's a feature..............in all seriousness a LOT of LCR's do this
try the cheapest solution first, a can of wd40 sprayed all over the rear suspension, let it work in.......it helped on my old LCR.
Im trying to remember but Im sure Ive had them re-greased and rotates under warranty...but thats run out now...so I will take a look at the weekend and see whats what...
I only suggest that as tracing 'a squeak' may take a huge amount of time and money. I know it's annoying but I doubt it's anything major.
As your car is a '55 it must have just been MOT'd? Guess the bushes can't have been too bad condition wise.
Indeed - just MOT'd - no probs...I dont think its a problem its just really anoying.
yep mine does this too and mine is a 55 plate....only happens in the wet. dont think it is anything serious mate, just cheapo dampers im afraid...
Some bits of the car are great but its things like this that really let it down...imo.
I fully understand what you mean..........even embarassing at times
But I suggest start with cheap options then it's going to be trial and error to resolve it i'm afraid :shrug:
Indeed...:)..designed in Germany, built in Spain...fixed in England.
dont understand why SEAT didnt make the suspension slightly better from the factory?..when they came out they were £18k..they could of sold it for £19k and fitted ARBS and better dampers im sure
got top mount part number of 1J0 513 353 D.. there only 15 quid each so could be worth the change..
like i say when i worked at seat garage we changed a few of them..
Ive actaully had the front top mounts replaced for a noise...was it generally rears you had to replace?
I might give it a go.
i have noticed mine creek a bit on the back over speed bumps but i have just added a 28mm bar so i blame it on that
