East london20vT
70
east london
I have been trying to get the number plate bulbs out of my car to do the normal replacement with L.E.D one, how do you get them out, I have tried getting a small flat head screw drive behind it and pop it you but it is not moving,I dont think the weather is helping as i can only lay on the floor for two mins.lol Am I doing this right??
They should just pop out but yes the weather probably doesn't help :D.
You'd be better to get the flat blade to one side of the bulb rather than behind. They are in quite tight.
PS: Keep an eye on the LED ones. None of mine have lasted that long. Couple of months at most. Tried quite a few different ones with the same results. Am now trying these:
http://cgi.ebay.co.uk/WHITE-39mm-LE...14&_trkparms=72:1301|66:2|65:12|39:1|240:1318
Are these the exact ones for LCR's? If so i'm guessing i'd need 2?
Yeah 39mm fits fine. Try them I've had several 8/6 bulb festoons and they don't last. Could be my charging system blowing them quickly but the normal bulbs are fine. I'll see how I get on with the ones above. I use this type in my boot and glove box too, although different sizes.
I wouldn't get the blue ones unless you wan't them to match your washer jet neons :D
That's the fella Lee, I got mine from him. However the 6/8 bulb ones still didn't last. Might be my car though :lol:
