been offerd a vectra sri £600 that im tempted by
Just makesure what your hopping into isnt as bad as what your hopping out of
No, more likely the lever that pushes on the thrust bearing is turning on its splines on the operating shaft. (The shaft that the outer lever operates).
You need to prise the round (VW stamped) cap off the end of the box and have a look.
thats what i thought by surely that souldnt stop me from puting it into gear
If its the release bearing it will have failed and wont be releasing the drive correctly meaning the box won't shift gears.
Rich, does you clutch cable operate a big lever on the front of the gearbox which pivots at the nearside end of the box?
yeah it dose dave?
that looks like the 5th gear and selector on mine 02A? (can never get used to the types)
