right heres some pics
hope these help
so any ideas or pointers anyone?i may have a little something up my sleeve but that maybe reveled on teusday
I'm pretty sure there's a drain plug on the gearbox.
You need to get gearbox oil. Castrol do one, or if you're feeling flush then the Redline oils are meant to be very good.
C-kid - last 2 i have done have been dry but tilt it up to be safe as the cap is lower than the fill bung, gearbox only holds a few litres anyway and if you do spill any the bung you see in the pic can be easily topped up
just looking at your rich - not seen the box before - that end cover looks similar to mine at that end
your cable goes out and down and back towards the bulkhead - looks manual too and adjusted right up but your fault could be: stretched cable / dreaded pedal box / knackered release bearing+plate
gonna be a job to say without looking inside but looks piss easy compared to some to be honest
the bearing lever assy splines in similar to DPJ's one but is held in 2 places and usually stronger but if it has slipped/broke i'd have thought you wouldn't get any clutch at all really
the noises ya getting are they changing when you pedal it ? thrust bearings worn out usually rattle more when off pedal then the pressure seem to quieten em off
might have found a pic for ya
hummm,i thinking it the thrust bearing!so im going to have to try strip it down and have a look,peddle box looks fine,strech cable?well i think ill replace this to!!
as regards the side of the box it got a VW stamp on the middle of it!
so then people were do i start to strip the box down any advice?any thing i should or shouldnt do?
cover back on first as your is different to the one we all thought it was lol :)
battery disconnected / starter out / shafts out / gearchange and cable
then undo bolts from there really
ok chears mate,ill try plod on dueing the week if i can as i cut all my hand open in several places last night
well just thought id let you know going on!havnt done much as iv bust my hand up so iv been offered a mondeo st24 as a runaround so i may take it off the road and put a abf as it may work out cheaper and better!as i need new pads and disks aswell so im looking out for a writen off gti/cupra or engine and loom!
Take the ST24 its a bloody good car!
