Mounted the Danny way i see :p
Is that not gunna get a bit warm with it being right over the turbo, when your trying to adjust it to set it up?
Its fine it aint going anywere as there a bracket just behind the mbc which holds it in black the ties are to keep it the correct way up...
I will Bolt it to my Strut brace when it isnt -5 outside so this will do lol
Right My engine consists so far
Atp Gt2x turbo
Atp 2.5 tip
Atp Manifold
3'' Downpipe & De-cat With Heat wrap.
2.5 milltek System Non Resonated
3'' Maf
Jetex Filter
440cc Injectors @ 4bar
Mocal Oil Cooler
Ecu/Map @ starperformance
TurboSmart MBC
N112,N249 & SAI Removal
EGR Removal
Oil Catch tank
Oil temp Gauge & Sender
Boost gauge
Vr6 helix Clutch & fiblanza lightend G60 Flywheel
Universal Intercooler With Uprated 68mm piperwork to turbo
i will be running 1.5bar aswell
Is the spec alright do you think?
Next would be:
4pots
Arbs
EBC
Tubular Mani..
its only the a/c radiator that will need moving, which isn't too hard. i'm guessing it means drilling new holes and mounting it a bit further back :)
just dnt know if it involved alot of pissin about like as this is something i may want to do
