unless maybe i swap the unit with the storage as you said above.
Dont spend £40.00 on the fitting kit - http://www.lowcostcaraudio.co.uk/lc...0+postage+only+400+vw+facia+panel/pid/8002020
this is under £15 inc postage and will do the job perfectly.
simonfouracre - Thanks for the clarification! I've never tried taking the stereo out before so that's probably half the problem
Any advice on the best way to remove and smooth the brackets? Is it a simple case of physically ripping them out and using fine sand paper to smooth?
Big reps for the link also, looks like you saved me a good £25 on the fitting kit![]()
mhill - how do you fit a double din unit without a surround then??? would like to see yours if it fits straight in the hole you're left with!!!
