Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
:cry: It failed Worn Front brake pipe the flexie one, and rear brake light bulb blown, interesting thing is i have a small number plate on and as of April it will fail the mot, (good job i have the original and some velcro for next year) also the centre exhaust bracket had snapped but not failed on it, and outer cv boot split also not a fail, having all done on Tuesday, going to put braided hoses on, and replace the centre section with the diesel centre section as it has not got the silencer in it, for £20 worth a go:D
http://www.motuk.co.uk/manual_250.htm
E. Front Wheel Drive Shafts and Couplings
Inspect as follows while the front wheels are jacked up
1. With the vehicle in neutral gear, rotate the wheels when they are on each lock in turn, and check visually the gaiters of the outer constant velocity joints while the pleats are expanded.
1. a. an outer constant velocity joint gaiter missing, split or insecurely mounted to its housing
My centre mount has gone on mine and was rattling, so i bodged it with a jub clip, ive got the MOT end of this month, think it'll get through? Its not loose, i just fixed it with what i had to hand lol. Meh, might take it an exhaust place anyway, need to price up a mufflerectomy :rolleyes:
