Ollie didnt go!Ollie (camera man on the floor) owns a diesel too, so he knew what was coming once they put their foot down! lol
Jonjay how ever like a thin coating of soot on his face it seems, as he doesnt move a foot with camera in hand, harden TDI owner!! lol
Already on the case. Spoke to Phil you used to work next door to AmD who started his own tuning garage in Surrey. If I don't have any luck with SFS he will fabricate me a system. He is definitely **** hot on tuning side of things so I should be in safe hands.Just an idea but could you not go to a custom exhaust center and get them to make the tubeing from Stainless steel, You could then have them polished
My one is totally cured now. Driving around today was great as I was taking it easy and no noises to annoy me.my vibration was down to my new custom boost hose vibrating on the power steering fluid bottle while on idle, with a bit of sponge, the problem is sorted![]()
I cant just leave as it is as its causing lag that shouldnt be there. If you driving normally and need to put your footdown its not good.I think if you stick stainless tubing in place of the SFS stuff all you'll do is transfer the problem to the next weakest part which will be the IC end caps and they'll blow off.
Yes same here when I had stage 1 but since big turbo they are swelling massively. It definitely the pipes without a doubt as once they have expanded there is no lag.That's just weird cos i'm not getting that effect at all - mine seems smoother and a lot less jerky.
