Cainey
48
Merseyside
Hello there,
Been a member for a couple of years but I've not posted much. However due to a recent service at a main dealer I find myself in need of some help so here I am.
Just had the 40K service on my LCR 03 which has highlighted the following issues. (with parts and labour quotes)
Bracket snapped off the back box : £269.39 (not sure if that includes a new back box or just a new bracket)
Front Pads 90% worn and discs excessively lipped on edges : £492.80 (I've searched and found Badger 5 so I'll go via him)
Turbo Oil Feed Pipe from sump dented £144.23
Requires front splitter (no price given)
Four Wheel alignment. (no price given)
If anyone can advise on where I can get these parts and fitted cheaper I'd be very grateful.
Also is it normal for a main dealer to charge for a courtesy car? What the hell is an enviromental charge too?
Cainey
Cheers UncleFester
Just read a few posts and found the bracket can normally just be welded for a few quid. So hopefully a few pennies saved there too.
front pads are a piece of cake to change and will save you 85% of the brake change (which is v. over the top), do a search on here and you'll find a great step by step guide to fitting.
