jcp
216
Herts
Not a new mod or postbut just such fine value.
Parts needed:
Ref: 1K0 915 336 B (back cover)
Ref: 1K0 915 335 C (front cover)
Ref: 1K0 915 443 A (Top cover)
£16 from your local VW dealer- these numbers worked last week.
Tools needed - small spanner for battery terminals and larger spanner for battery anchor bracket.
Method:
1. Disconnect both battery terminals.
2. Remove hideous felt battery sleeve
3. Unclamp and remove battery
3. Fit rear half of new 3 piece battery box
4. Replace and re clamp battery
5. Fit front half of new battery box
6. fit lid and admire!!
[B)]
These battery covers are fitted as standard on VW Caddy van TDi, so should be OK. I'm hopefully going to find out as a mate has a van not being used at the mo, so I will be able to check.
I agree it is a pearoast but was so pleased I couldn't resist writing it up again- every time I opened the bonnet and got over the cheap nasty bit of wire which you prop it with I would see the poverty spec black felt battery cover and wince at the cheapskate who thought it would be OK to have a piece of cr*p like that under the bonnet.
