nd-photo.nl
5,326
1,233
The Netherlands
youtube.com
Swapping over the battery is quite an easy DIY job, which you can do at home. Don't forget coding the battery to the car for the best longevity of your car battery. Especially when you swap over an EFB battery for a better AGM battery, as I did. This was one of the first times working on my Cupra, so I didn't know you had to remove part of the air intake to gain more access :giggle:
My old Banner battery had a "dotcode" for the battery: 2215, which stands for week 22-2015
AP1GczPcE5syxxtOU5fSTyafUjDOrq2d0gaJmKNNP4BV0QPGZjwMN9F2ZCKJk6Defl-3wcyZIr6YXF3vFlERDWZuuZsqoPWDuI00ZFRQSYp4tG-J_XvJWBWqQC7MwF2MhHE0Um2_XaEtWP_ycvNQIXLbcXIObA=w1920-h1080-s-no-gm
I replaced it with an Exide EK720
AP1GczM1bx9ab1zoxWbb5fKJVHR_-G3txMuDh7CO8D4ZO-hrsffLzbKrQjf7teY49TMhknIUh72lpdceEvardp0HRb-vESPXtY00GHEdytd5jhbpfCZBmHAOw8ZPTTeX8hVdlowhPoC6Q84N2UbiSQZ9uepu2g=w1920-h1080-s-no-gm
For the VCDS part:​
- Battery adaptation-Rated battery capacity​
Change the value if you put a bigger/smaller battery in. The value is almost always printed on your new battery
- Change/check: Battery adaptation-Battery technology​
I went from EFB to AGM. When you put in a AGM battery, choose FLEECE (!) and not "Binary - AGM"
AP1GczPNeHYzRvp5eBWQNo-lre521NPqZpn1M5Dxafl8dOLuqJ2gLYK8D6SZ-h2koPJWmt4_NCsX_SLxsJtX3xFg0ccXMMNNTWT3rpf6bh-vyCE5ovPJ9q94zU0jcuwRJcLHOJd9CuOxhr1qzPv78YZO3Aem8Q=w1920-h1080-s-no-gm
- Battery adaptation-Battery manufacturer​
If you swap to another brand, use one of these codes:
AP1GczNC5s_JPdWUlO0n8f3MQfPhMisaHM6afhQ1I-0AIwAZgETNh8zY1jMrN6AHLQEP-9QO0oSzMEnLDRAXXpOc4VcCCZ0jYBWN9EyHtI7bR_NJjP8j9VSa1s0S2XjLCEfz_3lhY9EgUgV_zR0s32tLr7GtYQ=w1920-h1080-s-no-gm
- Battery adaptation-Battery serial number​
If your new battery has a serial number, change it in this field
Step-by-step video guide​
