Moffat
Cupra R
Mar 29, 2009
61
Alnwick, Northumberland
Engine managemment light came on tonight so i checked it using the heater control panel trick.
Came up with 22.1, which is : A/C Refrigerant High Pressure Switch, static open, *22.1
(*22.1 Compressor remains off until switch closes )
What does that mean? Remains off until switch closes, does that mean there's a sticky valve or something?
I've got exactly the same problem and started a thread about it last night. I also did a little bit of internet research and found this - http://www.honestjohn.co.uk/forum/post/index.htm?t=15023&m=152519&v=e
I take it your air con doesn't work at the moment too then?
No mine doesn't work. when you have the car running and you press the aircon button, you can't hear the ac pump kick in like i have on other cars. Mine's currently in the garage getting some other work done, and the lad s going to chck the system for me tomorrow just incase it's low on gas. i'll let you know if it works or not.
Yep, mine is exactly the same. I'm really interested as to how you get on with yours, so if you could let me know that would be great. :happy:
Edit: Did you read that other thread I linked to above?
one_eyed_king: Just tried it in the car park and it reports a fault code of "22.1" - A/C Refrigerant High Pressure Switch, static open. (The compressor will remain off until the switch closes). This should be a warranty job anyway, but I hate going to main dealers blind. Does anyone know what a A/C High Pressure Switch is by any chance?
Dave N: The a/c high pressure switch protects the system from high presssures by opening at 35bar, but should then close again when it drops to around 28bar. What's interesting is did it just open, or did it see high pressures, open, then fail to close again? If the later, then obviously the cause needs to be determined rather than just putting a new switch on and hoping for the best. Usual cause of HP is fan failure.
one_eye_king: Thanks for that, Dave N. The reason I asked was because I was wondering if the recent very hot weather had overstressed the system in some way.
When you say fan I assume you don't mean the engine cooling fan?
Forgive my ignorance.
Dave N: I do mean the engine cooling fan. There are 2 of them, and they run at half speed all the time the a/c is on. The more load on the system, the higher the high side pressure goes. If it reaches 17.5 bar, then both fans go to full speed. If the pressure carries on going up (which is very unlikely), then the HP switch cuts the whole lot. When this happens, the pressures subside, and the whole lot turns itself back on when it drops to 28 bar. If there's something wrong with the system, then the pressures shoot up to 35, it cuts off, and so on. You will normally notice this happening as it will cycle every 3 or 4 seconds, jolting you about as it bangs on and off, loading then unloading the engine.
As I said before, pressures will only normally get up this high if the fans fail, though it can be caused by too much refrigerant in the system, and only show itself when it gets really hot. It may be the switch has just plain broken, in which case none of the above applies, but as the switch is actually a 3 position switch, that opens at low pressure, closes at normal pressure, then opens again at high, it seems a bit odd that it has failed on the HP part, whereas one would expect it to fail to the low pressure setting. That's why you just need for the dealer to check that it's a straight switch failure, and not one preceded by a high pressure situation, otherwise you'll be back there again with poor a/c.
Doesn't sound too good. Come to think of it, I haven't noticed my fans working recently. Especially as I was sat in traffic in London on Saturday and it was baking hot. My temp needle never went above 90 though. Bloody cars! [:@]
Cheers for the update mate. I guess I'll have to get mine re-gassed and go from there.
It's only taken me a year, but I got mine re-gassed today at Kwik-Fit for £49. It was completely empty apparently. I now have fully working climate control and the diagnostics thingy is showing no fault codes. Result!
