DAN T
hi. today it come on dash :( the emission light , look into and is oxigen sensors or cat:cry:, anyone knows how much for the this CAT sensors ? is hard to change them ?
cheers :worship:
If you mean Lambda sensor then I think it is about £80 for a proper Bosch one (don't buy cheap guff, stick with OEM). You will need to vagcom it to find out whether it is the pre or post cat sensor that is muntered. Not a tricky job to replace it though.
Will the numbers from a normal code reader tell you what sensor it is?
If so I see your from Norwich and I'd be willing to meet you in Beccles to plug my code reader in if its going to help?
cheers :worship:
Are you sure its a sensor?
That light does not always mean its directly a prob with emissions. What code have you got?
VAG-COM don t say witch sensor is , i can clear that and is coming back after a day , when i look into vag-com where is the parameter reader and there is say sensor oxigen failed both of them and CAT.
when check no fault coming up, i will go later to my mate and plug vag-com:( again.
I had this when i bought the car and under warranty they change one sensor but i dont know witch one:confused:
anyone has a pic from this DVD manuals (exaust system) to see where this sensors are?
cheers
Have you had a high flow exhaust fitted by any chance?
hi m8 ,
if the market in Beccels is on maybe i can come sunday there and is ok to plug your code reader. :) to see with what is come up.
cheers
The market is pretty much dead now mate but I can meet you pretty much anytime..........I can meet you in Beccles in a bit if you like?
just check the car , no faults come up , but when i go into engine and from there into readiness here is the come up with Oxygen sensor heating =Failed or incomplete Oxygen sensor(S) =Failed or incomplete Catalytic converter =failed or incomplete.
when i look first time with the light on the dash it come up just the CAT after i clear faults the light gone off and look again into readiness it come up with all 3:(
anyone knows please where are this sensor located Oxygen sensor heating+Oxygen sensor(S)
cheers:help:
hi m8 , i will try maybe tomorrow
cheers
That should be ok....Its only a fault code reader tho if Vagcom won't pick up the code then I'm guessing there is no code for my code reader to read?
Your welcome to try it if you want tho I'm free during the day and can prob pop out in evening for a bit if needed.
