ko3s fitted.....bored :(
tobi20v
87
Germany
Wow, 280hp with the original manifold ? aren't the 30mm average of the pipes to small for 280hp ? If you have to buy a upgrade manifold for the turbo, you can directly go on gt2860 oder 2871 :)
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
I'm sure we can do it it's only nuts and bolts:D
nice one mate just picked that turbo up the (ko3s)lol wich was acualy a ko3 but it dont bother me as its gunna be sent of next week to crt..the turbo blades are blits and it seems that there is sand in the thing fook knows whats gone on there ant even an acuator on it but it was gunna go for an uprated one of them on there anyway same as bennys done
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Actuator rated to 13-15psi is what you want, mention it to CRT when you call them and they can sort it out for you.
Oct 31, 2006
870
Cambs
Good job it was cheap then mate if thats the case, how long are CRT going to have it?
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Carnt complain with the CR turbos hybrid, mine made 276bhp and 292 ft lb last year-and even then it was struggerling to hold boost so i think ive now got a weak actuator as im loosing boost...so need ask CR turbos if they uprated mine at the time... either that or a boost leak.
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
I know its only 10-20bhp but how come initial rating on ko3s hybrid was 280-300bhp and now its more 260-270? Still, its a great power output from a small free spooling turbo
Benny, does your hybrid make a louder spooling noise compared to your normal ko3s setup?
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
think its more the map...the hybrid prob max out at about 300 mark like the k03 stage 1 is 200 but max is only 210...
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
LOL, louder is a understatment! I even PM`d Bill to ask if jamie B`s turbo whistle was loud as i was worried i may of had a leak!
Just got back in from abit of a drive and im still loving it!
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Try a pressure test mate, Bill uses a good way with a foot pump i think, there supposed to start opening between 13-15psi.
What are you boosting too?
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
bill is the man for the job! had mine done last weds, will give my full verdict im my readers ride thread i will be doin in the week. mine was ko4 023 not hybrid tho. the new map is a different world to the old map.
