dannt please dont tell me thats from powerflow
make sure its tig'd. mine cost me about £1000 i think
Yeah Il defo get pictures up of New Tip but im gonna trace around this bracket ive got and upload it on here so people can just simply print it off and use it as a exact temp plate...Then get a small peice of gauge steel from B&Q and drill 4 holes in too it...
Then should be easyer for people to run a larger Turbo intake pipe..
Danny your too kindThats actually quite a good idea though mate!
I'll take a look at that bracket too. Thanks.
dont you want 3 lambda ports?
post lambda probe has to be electrically connected does it not? mapped out signal wise but not hardware wise
egt as close to the hotside as possible obviously
egt 1st (as close as poss) lambda 1" from there, 18" for afr, 2nd lambda abit after that
http://www.merlinmotorsport.co.uk/p2374/M12-X-1-SHORT-BANJO-BOLT--(SS)/product_info.html
You will need 2 washer's aswell.
