if you have electric adjustable mirrors, when you move the drivers side mirror, it tries to automatically get the passenger side into the right place for your head position without your input... have a try!! saves hassle if you share with a much smaller or bigger other half!
Weird, I thought my passenger mirror had moved the other day, after adjusting the drivers side, I thought I was losing it :D
oh and theres always the diagnostic thing on your climate control if it hasnt been mentioned? hold recirc button and press the 'up' arrow. (when engine is running and AC is on) a wierd number (1c or something) will be displayed. Press the '+' and '-' buttons on the fan level side to cycle through about 60 parameters including digital readouts of engine RPM and 'actual' coolant temp (number 51 i think). The press the recirc button to display the value. pabs has put a list of what all the numbers correspond to in the infobase section of SCN (off the home page)
just tried this an works but dont nat numbers mean you no where about the page with what numbers mean is? cheers
The electric mirrors are supposed to position themselves in a different place when you select reverse as well but mine have never
