biggest front disks??
andyj
There's no F in Quality..
without changing you hubs, the biggest you can go to is the ones you've got - 239mm (solid or vented depending on your callipers).
to go any larger you will need to change you hubs......
then your 'easy' options are:
256mm from a 2.0 8v Mk2
280mm from a 2.0 16v Mk2 or 1.8 20vT Mk3
305mm from a 1.8 20vT Mk3 Ibiza Cupra R (Brembo 4-pots)
ibizaboi
392
Sudbury
ooow man that sucks!! lol
andy j o wise 1 by any chance would u no where i could get some from and wot i would be looking at lol
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
Are the calipers on 280's the same as 256's? Would i just need a different caliper carrier to go from the 256 to the 280's? Will 280's fit under 14" wheels as well?
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
280s wont go under 14". and the callipers are different for 256 (8v gti) and 280mm (16v)
passats/golfs/ibizas/cordoba blah blah blah all share the same front hub/brake set up. just watch out you dont end up getting 5 stud hubs.
Mellow Yello
Pedros Dodgy Windows
Jun 13, 2008
112
am i right in thinking that since the 16v's come with 16" ronals standard the 280mm's wont fit under 15s? as im needing new disks and pads as mine are warped , but i quite fancy having bigger brakes to suit my engine mods im planning?
thanks cole
Mellow Yello
Jun 13, 2008
112
thats fine then , just got new wheels so id be gutted if i could fit them under the wheels :D
