NokNok
Hope someone can help me.
We recently started having water literally raining down into the passenger side foot well. Occasionally a little spills into the drivers side (out of blower vents) but not much.
It usually happens on hills or when swinging into turns.
We don't have a sun roof, and we have not really been using washers front/rear much. I originally thought it may be AC related as the water coming through is quite cold but we hardly use the AC. I can only think it's rain water from windscreen. I've also read about blocked pollen filters??
Water is coming from top left area of foot well near where the carpet ends, the carpet is soaking and if you pull it back sometime more water drains in. It's very difficult to actually see where it's coming from. Could it be through ventilation?
Last week I hoovered out all the debris/leaves from corners of engine bay as well as I could with the limited access and pored some water down both sides. It immediately starts draining out the wheel arch onto the road but no flow seen in footwell so it's seems it's pooling somewhere. Maybe the drain are blocked deep down out of sight?
Also I notice in the wheel arch area, the water drains out from different areas along the 'seam' in the arch. I can get my fingers all along the seam but can't see if the water should drain from one point only? Would this suggest a blockage?? I've also read about door problems??
I'd really appreciate some of your joint experiences or guidance on where to check.....
