no bother. now that that is sorted im toying with the idea of these....
http://www.powerbulbs.com/product_detail.asp?prod=102
EDIT= Now purchased![]()
If its for sidelights then you;ve bought the wrong fitment, you need the W5W
type fitment
http://www.powerbulbs.com/product_detail.asp?prod=128
well i have both sets of bulbs now fitted and im happy with the outcomepleased to say the LED's work with no warning lights or anything! will get pics up shortly.
what side light led's did you buy? can you post a link please.![]()
Hope i haven't cost anyone else the same £24.04, shouldn't have been so quick to post that they were a solution to the hateful problem that is SEAT's electrical system. i may try and find somebody who has the VAGCOM software and hopefully will be able to remove the "bulb out" feature completely!
fitting resistors is the only way around this. even the PIAA ones have resistors fitted.
Really? are they fitted within the actual bulb unit as i thought they were completely plug and play...? I have tried fitting a resistor at one side of the car for previous LED's and this didnt work either... im getting really fed up with it, its a completely unnecessary feature!!
