xeroz18
Hello everybody. I got a seat toledo from 1994. And now i need a new ignition switch. So i'm just wondering what kind of ignition switch it is in my car. And how do i replace it.
Thanks / Simon
when you say switch do you mean just the electrical part ? or the ignition lock itself ?
Hi again. I think it is part number 5 on the picture i want to remove. It must be there it is going wrong. The start motor doesnt get any signals to turn. But when i take a small cable on battery plus and to the kontakt on the start motor it is starting. I dont knoew what the kontakt on the start motor is called in english. But it is the kontakt whit one small red/black cable on it.
thanks / simon
we call it the switch or as you say contact / kontakt and is a common fault for what you describe
if you unplug the wires #8
look from underneath to see the screw #6
undo that and the switch will pull out
vi appellen det koppla eller som dig något att sägakontakten/kontakt och är en allmänning kritiserar för vad du beskriver
om du kopplar från binder #8
se från under för att se skruva #6
ångra det och det koppla ska handtag ut
Hi again. Thanks for the answers.
I have bought the new contact. BUT i cant find the screw underneath it. SO now i wonder how the h*ll[:@] am i gong to change the contact. I have thinking for ours whiout get any idea. Thats why i am frustreated. Not on you guys :p Appreciate fast answers .I couldnt insert pictures until i made 15 post.
/Simon
Replace the switch contact. MK1 -94
Hello i'm about switch contact that is behind the engineswitch, Beside the sterring wheel. But i cant get the old one out of there. There are suppose to be a screw underneath. But in my car there isn't anyone.
But look at my other tread.
And you will understand.
/Thanks Simon
Damn you are fast fl@pper.
Ok so how do i get in to it. It looks like fort knox :p..
/ Simon
gimme 5 minutes and ill take a pic of the ibiza if i can and show ya
always thought i'd done one with a long thin screwdriver but uncertain if lock assy has to be removed hmmm
be back in 5 mins
it is as i thought - steering wheel off and ignition switch off the column to get at it, i knew it rang a bell sorry
Yea i thought so to when i looked at it. But i hoped not. Now how do i get the steering wheel off. The "mutter" (in swedish). Screw that holds the whhel it is some blue stuff all over it. I feeled on it before and sat tight very thight, how is the easiest way to get it off. is it just to take a wrench and just screw it off. Whit muscles like a horse
OK so now i have taken the steering wheel off, and the electrics.
Do i have loosen the steeering shaft too? cause the auluminum chunk still wont move. And i have loosen the insex screw. Or is it just to keep on push and draw until it loosen up. I thinking of all the bearings and so on.
Hello aain i have now replaced the old contact, But it stil doesnt want to start.
any ideas? I have changed the startengine, relay, and now the contact.
/Simon
the startengine wont turn at all. not a sound. The only things that happens is that the gaspump start to suck. And the start relay clicks.
do the ignition light's dim and dissapear?
battery voltage ok ?
have you tested the starter motor in anyway ?
when you say relay 'clicks' is it a light tapping noise under the dash or a fairly heavy 'clunk' under the bonnet
may be worth looking under the bonnet whilst someone operates it for you
Yeah i can start engine with the ignition on.and i take a cable from the battery plus to the small contact on the startengine. and just toch it for a second.
so starter motor is ok then - yet new contact isn't working ??
can you unplug the wiring and plug in the old one to test it ??
i guess you are not getting a +12v on the signal (small) wire on the starter motor
