paul-murphys
efr 6758 here i come
i'm getting my turbo made hybrid an gettin a forge actuator fitted as well. Do i need to adjust it when i fit on car or do you adjust them by changing the spring in them an what spring you have in yours. Also you said had to basically take turbo off. When you did this what parts did you fit new to car as in gaskits. Thankyou.No dont need to be mapped just holds the boost longer so give a stronger pull through the gears. mine made about 10 bhp through out the rev range, holds at a good 24 psi now to the red line.
