DaNnY_LaD's IHI'd Cupra ( End Of a Eara 08/11/2009)
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Hi everyone ..
What is the Ideal AFR mixture?
As im Seeing 10.8 to 11.0 afr On Full W.O.T in 3rd @ 1.4bar all the way to the limiter...Now ive heard this mixture is to keep the EGT down...Safe tune or what ever they call it ive also noticed after some Searious fun with it....The Manifold Doesn't even glow like i thought it would.
But for people Saying ''How does it drive'' It feels a little too quick to be running right.if you get me seems i was too used for the old GT2x Spool..
Any advice thanks
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Compared to mine thats richer than it needs to be on WOT even to be safe for the IHI. Make it a little leaner and you will get more power. Also holding 1.4 bar to the limiter would be possibly pushing it for your rods in some peoples eyes.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Thanks Pj...
Currently bought a Revo select plus so i can sort out some of the timing Plus i haven't adjusted it via lemmiwinks...
I Don't drive it anywere on the nail though But rods are next on my list of thinks todo...
Also Pj how would imake it a little leaner?
thanks..
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Righto i did some logging tonight with Curzon & lauren to see what the Stock Revo stage 3 Is giving on my IHI but i couldn't take it to the limiter due to silly speeds and weather..
Ive Currently Got a SPS3 on order so its all good and my boost is set at 20psi...As for My AFR its around 10.8-11.0 On full W.O.T in 3rd to limiter..
But Curzon will Post up a Describtion and the Logs..
Thanks Comments welcome.
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Right here we go not great logs as Danny didnt want to take it right to the limit and it was wet so it just kept spinning up
These are the first few, hadn't changed anything at this point
Code:
	Group A:	'002				Group B:	'020
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
MARKER	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF
	0	1760	78.2	6.56	27.83	0.4	0	0	0	0
	0.8	1920	79.7	6.15	30.28	1.2	0	0	0	0
	1.6	2120	85.7	6.56	34.06	2	0	1.5	0	1.5
	2.4	2320	94.7	7.38	43.81	2.91	0	1.5	0	1.5
	3.41	2560	100	8.61	50.44	3.81	0	0.8	1.5	0.8
	4.21	2800	106.8	9.84	57.78	4.61	0	0.8	1.5	0.8
	5.01	3040	118	10.66	71.69	5.52	0	0	0.8	0
	6.01	3440	144.4	13.94	98.94	6.51	1.5	0	0.8	0
	6.91	3880	183.5	17.63	140.03	7.31	1.5	0	0	0
	7.71	4360	191.7	19.27	167.08	8.11	1.5	0	0	0
	8.51	5160	191.7	20.91	204.22	8.91	1.5	0	0	0
	9.31	5840	191.7	20.09	227.47	9.71	0	0	0	0
	10.11	4160	14.3	1.23	8	10.51	0	0	0	0
	10.89	3440	6.8	0	3.44	11.29	0	0	0	0
	11.69	3080	8.3	0	5.08	12.09	0	0	0	0
Code:
	Group A:	'115				Group B:	'118
		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar
	0.4	2280	90.2	1470	1180	0	2160	23	95.3	1120
	1.2	2480	97	1790	1300	0.8	2360	23	95.3	1240
	2.09	2720	103.8	1930	1400	1.69	2600	23	95.3	1360
	2.89	2960	113.5	2070	1510	2.49	2840	23	95.3	1450
	3.81	3240	132.3	2220	1720	3.31	3080	23	95.3	1590
	4.69	3640	165.4	2360	2080	4.29	3440	24	95.3	1900
	5.5	4240	191.7	2460	2480	5.1	3920	24	95.3	2300
	6.3	5400	191.7	2500	2530	5.9	4760	27	87.5	2530
	7.2	6560	186.5	2550	2370	6.8	6080	30	95.3	2450
	8	5440	15	990	1380	7.6	6280	32	0	2310
	8.8	3840	118	2080	1430	8.4	3680	30	95.3	1150
	9.6	3960	60.2	1210	1930	9.2	3920	30	1.2	1860
	10.4	3920	15.8	990	1150	10	3880	28	0	1380
	11.2	3840	6.8	990	1050	10.8	3880	27	0	1080
Code:
	Group A:	'002				Group B:	'115
		RPM	Load	Inj. On Time	Mass Flow		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME
MARKER	STAMP	 /min	%	 ms	 g/s	STAMP	 /min	%	 mbar	 mbar
	0.4	2880	6.8	0	3.06	0	2920	12	990	1100
	1.2	2800	8.3	0	4.78	0.8	2840	8.3	990	1050
	2.1	2720	9	0	5.17	1.7	2760	9	990	1030
	2.89	2680	9	0	4.92	2.49	2680	9	990	1030
	3.69	2640	27.1	2.46	16.08	3.29	2640	22.6	990	1020
	4.49	2720	74.4	6.97	41.39	4.09	2640	36.8	990	1010
	5.31	2880	88.7	7.38	50.94	4.89	2760	82	1140	1140
	6.21	3120	112.8	10.25	68.94	5.71	2960	96.2	1410	1330
	7.01	3400	140.6	13.12	93.92	6.61	3240	125.6	2220	1620
	7.81	3760	178.9	16.81	134.33	7.41	3560	158.6	2350	1980
	8.61	4200	191.7	19.27	168.44	8.21	4000	191.7	2450	2400
	9.41	5080	191.7	20.5	205.28	9.01	4600	191.7	2460	2520
	10.21	6080	191.7	19.27	229.39	9.81	5680	191.7	2530	2510
	11.01	4520	14.3	1.23	12.03	10.61	5720	48.1	990	1770
	11.81	3680	6	0	3.31	11.41	3760	12.8	990	1120
	12.59	3520	6.8	0	4.44	12.21	3600	6	990	1050
Then we changed the fuel on load down to 99.2% and did a few logs Danny still says the AFR is too rich but hes going to run it and test again when its dry see if it needs to be lowered some more or not
Code:
	TIME					TIME
	0.4	2360	83.5	6.56	38.97	0	0	0	0	0
	1.2	2520	95.5	7.38	46.28	0.8	0	0	0	0
	2	2720	103	8.2	54.39	1.6	0	0	0	0
	2.8	2960	112.8	10.25	67.25	2.4	0	0	0	0
	3.6	3200	127.1	11.48	81.75	3.2	0	0	0	0
	4.4	3520	151.1	14.76	104.08	4	1.5	0	0	0
	5.2	3920	184.2	17.22	141.92	4.8	1.5	0	0	0
	6	4360	191.7	18.86	167.11	5.6	2.3	0	0	0
	6.8	4720	191.7	19.68	183.25	6.4	2.3	0	0	0
	7.69	4440	29.3	1.64	4.31	7.29	2.3	0	0	0
	8.59	3720	8.3	0	6.08	8.09	0	0	0	0
Code:
	Group A:	'002
	TIME
	0	2600	36.8	5.33	32.83
	0.4	2680	77.4	6.56	41.39
	0.8	2760	85.7	8.61	49.08
	1.21	2880	94	9.43	55.44
	1.69	3000	104.5	9.43	61.39
	2.09	3160	113.5	10.25	72.89
	2.49	3280	125.6	11.48	85.97
	2.89	3440	139.8	13.12	97.22
	3.31	3640	157.9	15.17	114.28
	3.81	3920	183.5	17.22	143.22
	4.21	4120	191.7	18.45	155.78
	4.61	4360	191.7	18.86	171.47
	5.01	4800	191.7	19.68	189.67
	5.41	5360	191.7	20.5	214.72
	5.81	5000	38.3	3.69	2
	6.2	4360	16.5	1.23	11.94
	6.6	3720	12	0	5.39
	7	3640	6	0	3.14
9,335
South Wales
95.3% wg duty all the time and full boost by 4200 doesnt sound right to me.
Cant comment on the maf figures as im not that up on the scaling aspect.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
I know...
I really thought i was winning with it...I really Did..:cry:[:@]
Im gonna turn my Boost down 2morro..Seems thats 1.5bar were it should be 1.3bar ish..
Plus im more than certain ive got a boost leak.
9,335
South Wales
It supposed to be 1.5bar, look at what its requesting.
You might be underboosting because youre using an MBC which you just told me so that would give false readings for the WG duty.
You have no way of knowing now if you have a boost leak because your MBC might be bleeding off the boost to the required setting on it.
Personally i would go back to basics, stick the N75 back one, drop the boost to something like Boost 4-6 see what the WG duty and requested boost is like and go from there. If your hardware is good then you can use an MBC and so on.
Youre running before you can walk i think.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Just awesome Phil.
Just needed someone to point me in the right direction....Il switch back to the N75 tomorrow and take it from there..
Wilko
Badge snob
I don't know which gears you're using for the logs, but by the number of samples, i'm guessing 2nd and 3rd.
You really need to find a dual carriageway and nail it in 4th from under 2000rpm, all the way to 7000rpm.
You should see 1 bar by 3k and 1.4 before 3500rpm, but you won't in second, and in third you'll need to floor it at tickover to give the turbo enough time to spool. Use the higher gears, and you'll probably see wg duty drop aswell, though I'd still expect to see 80%+ at full boost, rising to max duty cycle by 5500rpm.
The airflow looks healthy. if you rev it past 6500, you'll see 240+ and maybe ever 250, which is bang on.
Don't worry about the afr. It's safe, and again it will be better controlled in the higher gears. Timing looks OK.
Install your MBC so that it limits maximum boost, and let the n75 do it's job. The mbc will stop boost overshoot then, but not control the boost.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
So it should spool sooner if i do it in 4th gear from low down like you mentioned..Also how do i plumb the N75 & MBC in together to work with each other...I mean Would it spike then settle or would it just hit and hold?
What Should i do with the AFR Wilko...Should i leave it as it is and or lean it out(Slighly) by using Unisettings...to make it Closer to Low 11's as at the moment on Full WOT its at 10.8/11.0 AFR...
Much appreactied though wilko,Bill,Pj & phil..
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Just Awesome Damo Cheers gonna do that now...If i can find my old t-peices..
How do they basically work together? Is it additional Spike (N75) then the MBC will Control the Boost(hold)....If so how do i turn the Spike down via a Sps3?
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
So ideally if ive got this right it goes:
Wastegate Then T peice then N75 one side and Mbc the Other side...
Then on the wastegate on the mbc to T-peice then + of Mbc to another t peice then to charge pipe..the same as N75 on the other side....kinda like a circle..
And i set the Boost via the MBC?
Damoegan
Oct 15, 2007
8,993
Newcastle
Thats what John was talking about, Danny.
N75+MBC will remove the boost spike :)
ps. Forgot to post that earlyer with the other pic.
Damoegan
Oct 15, 2007
8,993
Newcastle
:yes:
