j.cavo
8 valves of pure power
Aug 6, 2009
229
Liverpool
anyone know what sizes the pads are for a 2.0 gti 8v
oh and part nos. aswell plz :confused:
is this correct for the rear pads
ENGINE SIZE & ADDITIONAL INFO
2.0 8v
POSITION ON CAR
REAR
EBC PART NO
DP680
just rears ?
luckily the EBC rep just walked in this morning and gave me a new catalogue :)
DP680 is standards
DP2680 are same pad in greenstuff
DP3680C is Redstuff Ceramic
DP4680R is Yellowstuff Race
just rears ?
DP680 is standards
and fronts if you've got the catalogue
i would guess it's 256mm from the model
93-96
DP841 std
DP2841 green
DP3841C red
97-99
DP1112 std
DP21112 green
DP31112C red
might be reading it wrong but they dont list yellows for front in the book but try a 4 in front of teh numbers if looking online
nice 1 m8 yep that seems to be what im looking for guna clean all the crap of my discs and change the pads apparently it becomes inbedded in the pad so its best to change
Hey just be careful on the thickness of the pads. I went and managed to pick up the thicker set of pads and didnt realise until the car was jacked up last week.
But seems Fl@pper knows his brakes so should be ok.
havent had chance to sort them yet :headhurt:
Those pads are girling/lucas stylee jenk, do what i did and get genuine vw/seat pads from ebay for 99p :p. Now just to find genuine discs that cheap lol.
Just looked through a haynes manual and im pretty sure mine has the girling calipers.
Its got ATE standard pads on it at the moment but it would be nice to have abit more bite especially as its going on track. 99p was a lucky find, mega saving there :)
Anyone any idea if EBC supply new guide pin bolts with the pads?
shape looks familiar and part number seems to tie up sweet as
When I was looking at these yesterday I couldn't find a yellow listing for the 8v but could in the 16v. Then I realised the pads where the same, bar thickness sometimes? But EBC only do 16mm thick which is all good for the 8v so I understand.
They should supply a pair of bolts, as vw reccomend that you replace the bolt you remove every time. I think the replacement is only cause the new bolts come pre loctited and that if you loctited your old bolts you wouldnt have any problems.
Might fetch a tub of loctite as a prequation then, seems mad to supply new bolts when a little sachet of loctite is all thats needed. Cheers!
I'm not 100% sure thats the reason jenk, but definately seems like it to me when you look at the torques you tighten them too.
Ordered them! Should be with me tomorrow hopefully, then if I can find my locking wheel nut tool I'll have them fitted for the track action on saturday.
