fitting HID's
Tom--
hello! had a read on the other HID lights threads and little confused about how to fit them. I've bought a set of bi xenon hid lights off ebay so i have dipped and full beam hid instead of just dipped as I drive lot of unlit country roads so need full beam as well really.
how do I fit them though?!
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
filaments are a direct replacement for the bulbs if you ordered the right ones (H4 i would guess with Bi-xenon?)
wiring plugs in and just need to find a cosy place for the ballast control unit
Tom--
yep h4. so does it just clip into the existing holders?? and have to secure the ballasts somnewhere?
thanks
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
yes they just go in the original holders and the wires just go in the original looms...the only thing you need to do then is drill a hole in the light cover for the wires to go through and secure the balasts...
Tom--
apparantly the hid's are the wrong ones. I've got the h4 set which runs dipped and full off one bulb but my car has seperate bulbs for the dipped and main.
so which set of HID's will i need?
Tom--
cheers [B)]
does that just do dipped though? could do with both dipped and full.
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
You wont or shouldnt need full beam aswell...unless you plan on trying to recreate the sun.
Ive got 6k ones and can hardly tell the difference between dipped and full beam with the hid's.
CupraJimbob
agree h7's and if you get stuck where too put your ballasts i will post you a picture where i put mine
Hi mate I'd be grateful if you could post a pic where you mounted your ballast.
turbo009
Red Lightning
Jun 15, 2008
2,596
Grimsby North East Lincs
not the best pictures and sorry about quality.
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
Ive fixed my ballasts to the right of the battery on the pasanger side...
And on the drivers side just under the light on the shelf...
Tom--
Most people only bother doing dipped as they provide enough light on their own
the reason i'm after both is because a lot of my driving is on unlit country roads, like no lights at all and alongs moors no road markings so after as bright as possible really. would i need 2 seperate kits to have both though?
Tom--
dammit! looks like I'll swap the current set for H7's (right kit for a seat ibiza 1.6 sport??) then just get better bulbs for main beam.
cheers for all the help people!
