Lee M
Hi all,
I ordered some anti roll bars from AMD to be fitted to my LCR by them, 25mm front and 25mm rear. The pair that turned up to them are 25mm rear and 22mm front.
Is this still a good combination or is the front one a bit too small?
Lee
That will be a good combination.
I have a 23mm front and adjustable 28mm rear and the car feels great.
The OEM front one is 18/19mm so 22mm is a big difference
Excellent, thanks guys. Just wanted to make sure I was still getting a good setup, as it is a bit expensive to get wrong!!!
If you go below 50mm at the front you'll need to change the ARB where as if you'd got the 25mm/25mm setup you wouldn't of.
Damian @ DPM Performance
