turbin
ok, so I bought this 3" DP with 120cell cat off fleabay and can't wait to see what difference it makes if any. I'll also get a custom 3" catback made to fit.
From you who have this mod already; what torque gains can I expect? :p
My motor is boosting peak 23 psi steady 19-20 til a redline of 14psi.
I wouldent go 3" turbo back tbh, id use a 3" DP and a 2.75" custom cat back made. Obvious gains are less restriction - turbo spools up faster, a few 100 rpm quicker if i remeber.
yea, I was thinking about if anybody have measured the gain...
Why would you not do a catback in 3"?
hey guys, just to add, ive got a 3 inch full system all the way to the back and have no negative effects. infact i'd say the car breaths better and makes a lovely harmonic roar on full boost. plus as boost peeks there are no bottle neck effects so its completely free flow. as i am aware some do recommend a 2.75" cat back system as this creates back pressure and helps things but as far as i know the k04 is happy with a 3inch system as my lcr jabba'd is. ;-)
you'll enjoy the gains from the downpipe and decat as the downpipe is the main restriction on a mapped turbo. should pull bit harder .
gulzar
sweet. Actually Im getting a 120 cell cat. Should be backpressure enough there.. :D
sorry mate, i meant sports cat. i had a sports cat before but recently got rid of it. none the less you will notice a difference in power after fitment.:lol:
gulzar
Which make? Heard both good and bad news if its the one im thinking of.
Also youll need to get the car remapped once the DP is fitted as the car will run quite crap but once mapped youll love it.
by reducing the back pressure you loose low end torque, but gain bhp up high, depends what you want really.
blue flame produced the first batch of lcr exhausts on here years back and members lost power.
Id like to see the graph from the member that say they lost power. Would be a fantastic document to have...
The turbo spool up faster at lower rpm with a DP and breathes easier at higher rpm. As far as I understand turbos, they don't need any back pressure to operate, any extra resistance after the turbine is a big no no. The turbine is driven by exhaust from the engine(positive pressure) therefore you want as little positive pressure as possible AFTER the turbine. ie. Turbo back...
Prove me wrong and Ill stand corrected.
I found this on the i-n-t-e-r-n-e-t:
“Howdy,
This thread was brought to my attention by a friend of mine in hopes of shedding some light on the issue of exhaust size selection for turbocharged vehicles. Most of the facts have been covered already. FWIW I'm an turbocharger development engineer for Garrett Engine Boosting Systems.
N/A cars: As most of you know, the design of turbo exhaust systems runs counter to exhaust design for n/a vehicles. N/A cars utilize exhaust velocity (not backpressure) in the collector to aid in scavenging other cylinders during the blowdown process. It just so happens that to get the appropriate velocity, you have to squeeze down the diameter of the discharge of the collector (aka the exhaust), which also induces backpressure. The backpressure is an undesirable byproduct of the desire to have a certain degree of exhaust velocity. Go too big, and you lose velocity and its associated beneficial scavenging effect. Too small and the backpressure skyrockets, more than offsetting any gain made by scavenging. There is a happy medium here.
For turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end.
Downstream of the turbine (aka the turboback exhaust), you want the least backpressure possible. No ifs, ands, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turboback exhausts is valid. Here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure.
Again, less pressure downstream of the turbine is goodness. This approach minimizes the time-to-boost (maximizes boost response) and will improve engine VE throughout the rev range.
As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.”
"As for the geometry of the exhaust at the turbine discharge, the most optimal configuration would be a gradual increase in diameter from the turbine's exducer to the desired exhaust diameter-- via a straight conical diffuser of 7-12° included angle (to minimize flow separation and skin friction losses) mounted right at the turbine discharge. Many turbochargers found in diesels have this diffuser section cast right into the turbine housing. A hyperbolic increase in diameter (like a trumpet snorkus) is theoretically ideal but I've never seen one in use (and doubt it would be measurably superior to a straight diffuser). The wastegate flow would be via a completely divorced (separated from the main turbine discharge flow) dumptube. Due the realities of packaging, cost, and emissions compliance this config is rarely possible on street cars. You will, however, see this type of layout on dedicated race vehicles.
A large "bellmouth" config which combines the turbine discharge and wastegate flow (without a divider between the two) is certainly better than the compromised stock routing, but not as effective as the above.
If an integrated exhaust (non-divorced wastegate flow) is required, keep the wastegate flow separate from the main turbine discharge flow for ~12-18" before reintroducing it. This will minimize the impact on turbine efficiency-- the introduction of the wastegate flow disrupts the flow field of the main turbine discharge flow.
Necking the exhaust down to a suboptimal diameter is never a good idea, but if it is necessary, doing it further downstream is better than doing it close to the turbine discharge since it will minimize the exhaust's contribution to backpressure. Better yet: don't neck down the exhaust at all.
Also, the temperature of the exhaust coming out of a cat is higher than the inlet temperature, due to the exothermic oxidation of unburned hydrocarbons in the cat. So the total heat loss (and density increase) of the gases as it travels down the exhaust is not as prominent as it seems.
Another thing to keep in mind is that cylinder scavenging takes place where the flows from separate cylinders merge (i.e. in the collector). There is no such thing as cylinder scavenging downstream of the turbine, and hence, no reason to desire high exhaust velocity here. You will only introduce unwanted backpressure.
Other things you can do (in addition to choosing an appropriate diameter) to minimize exhaust backpressure in a turboback exhaust are: avoid crush-bent tubes (use mandrel bends); avoid tight-radius turns (keep it as straight as possible); avoid step changes in diameter; avoid "cheated" radii (cuts that are non-perpendicular); use a high flow cat; use a straight-thru perforated core muffler... etc.”
"Comparing the two bellmouth designs, I've never seen either one so I can only speculate. But based on your description, and assuming neither of them have a divider wall/tongue between the turbine discharge and wg dump, I'd venture that you'd be hard pressed to measure a difference between the two. The more gradual taper intuitively appears more desirable, but it's likely that it's beyond the point of diminishing returns. Either one sounds like it will improve the wastegate's discharge coefficient over the stock config, which will constitute the single biggest difference. This will allow more control over boost creep. Neither is as optimal as the divorced wastegate flow arrangement, however.
There's more to it, though-- if a larger bellmouth is excessively large right at the turbine discharge (a large step diameter increase), there will be an unrecoverable dump loss that will contribute to backpressure. This is why a gradual increase in diameter, like the conical diffuser mentioned earlier, is desirable at the turbine discharge.
As for primary lengths on turbo headers, it is advantageous to use equal-length primaries to time the arrival of the pulses at the turbine equally and to keep cylinder reversion balanced across all cylinders. This will improve boost response and the engine's VE. Equal-length is often difficult to achieve due to tight packaging, fabrication difficulty, and the desire to have runners of the shortest possible length.”
"Here's a worked example (simplified) of how larger exhausts help turbo cars:
Say you have a turbo operating at a turbine pressure ratio (aka expansion ratio) of 1.8:1. You have a small turboback exhaust that contributes, say, 10 psig backpressure at the turbine discharge at redline. The total backpressure seen by the engine (upstream of the turbine) in this case is:
(14.5 +10)*1.8 = 44.1 psia = 29.6 psig total backpressure
o here, the turbine contributed 19.6 psig of backpressure to the total.
Now you slap on a proper low-backpressure, big turboback exhaust. Same turbo, same boost, etc. You measure 3 psig backpressure at the turbine discharge. In this case the engine sees just 17 psig total backpressure! And the turbine's contribution to the total backpressure is reduced to 14 psig (note: this is 5.6 psig lower than its contribution in the "small turboback" case).
So in the end, the engine saw a reduction in backpressure of 12.6 psig when you swapped turbobacks in this example. This reduction in backpressure is where all the engine's VE gains come from.
This is why larger exhausts make such big gains on nearly all stock turbo cars-- the turbine compounds the downstream backpressure via its expansion ratio. This is also why bigger turbos make more power at a given boost level-- they improve engine VE by operating at lower turbine expansion ratios for a given boost level.
As you can see, the backpressure penalty of running a too-small exhaust (like 2.5" for 350 hp) will vary depending on the match. At a given power level, a smaller turbo will generally be operating at a higher turbine pressure ratio and so will actually make the engine more sensitive to the backpressure downstream of the turbine than a larger turbine/turbo would.
Well thats the first ive heard, loads of the s3 guys have seen gains in both bhp and torque at the bottom and top end when mapped accordingly.
I have a generic remap from BSR and Ive spoken with them and they say go for it.
The "brand" is metal off ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230373366825&_trkparms=tab=Watching
-theres no gaskets nor bolts included. Where can I find these?
All im saying mate is i know 2 guys who both had generic stage 1 maps and when fitted with a 3" DP and sports/de-cat there boost went all over the place as the turbo was wanting to spool up before the car was requesting boost causeing all kinds of running problems.
yeah thats over boost, hence why its a stage two mod,
it was the original run of blue flame exhausts about 3yrs ago, they did a group buy an people lost power, so they revised the design, as for the back pressure issuse, large turbos like the garrets dont need any back pressure hence why you get skylines/supras with big gains wehn decatted, smaller turbos like the kkk need a tiny ammount, thats all. but it is a big debate, that has gone on before and will go on again, and i cant be bothered to digg all the info out haha, my previous golf was stage two, it had a downpipe/decat but kept the standard pipe work till the back box which was a mufflerctomy, this car ran 217bhp but with 281ftlb at a peak of 3200-3400 revs so very usable, this was a k03s.
cars with milteks etc ran higher bhp but alot lower torque, near to the 250ftlbs mark.
Get a stage 2 remap and you'll be fine. Remeber the biggest retriction on our cars is the exhaust manifold itself.
results: Car runs friggin great! Turbo spools up faster. Same torque at the same RPM's as before the downpipe fitment a little better top end pull. All this talk about all the problems and power loss after adding a 3" DP never happened to me. none!
So, what is the best stage 2 software? :p I have a generic BSR remap now and I feel this is the bottleneck on my car now...
- it also sounds REALLY good all across the rev range !!!
I think all the comments about losses are in regards to a full 3" system not the DP and cat, if i understood it right the best system for sub 300bhp would be 3" DP and 2.75" cat back, anything from 300bhp (which in most cases would need a bigger turbo) would be better with a full 3" system.
