ibiza mk2 exhaust
vngtx
i have a massive back box made by cobra that was designed for a corsa, it barely fits. i want a new one that fits perfectly with the facelift rear bumper. are there any other cars that have back boxes that will fit? eg golf mk4, polo, etc
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
mk3 straight fit but not quite a 'perfect' fit mind you i've yet to see even a standard one fit perfect :)
vngtx
the one ive got is touchin the bottom lip of the rear bumper and is melting it :( plus its only held on by one bracket so its a bit sideways.
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
standard fitting then :p
can you not change the fittings get it lined up better ?
vngtx
it knocks againts the shocker bolt if i line it up straight, i had to weld sum pipes together and use half of the original back box pipes to make it fit, but when it gets really hot or i drive over speed bumps it comes loose again. theres 2 brackets at the bumper end. ive got one thru the mounting and the other is now attached to the body with a little metal strip just so it dusnt fall off.
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
My Mk3 Cupra exhaust is touching the bottom lip and it isnt melting the bit its touching.
Mk3 Cupra backbox is a good, not too loud or chavy. Has a nice burble to it.
Mine constantly knocks under the handbrake area. The 2 brackets are touching when the car is running.
j.cavo
8 valves of pure power
Aug 6, 2009
229
Liverpool
god thats annoying whean you have people in the car they all think its going to fall apart
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
adjust it then ? there is a sweet spot that's hard to find but is doable, mine's knocked once when i first put it on and been quiet ever since
vngtx
iv had another fiddle with it today and its just in the middle, not touching the bumper and not touchin the suspension, but still knocks :( im gonna sell it and get universal one. which exhaust looks best? anybody got pics of theirs?
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
the knocking usually comes from the middle box needing adjustment it's the key to getting it right usually get pushed in too far to the cat to be honest.
front joiner adjusts the front to back and rear joiner does the side to side
abhardwaj1990
Yes, I'm licking my hand
Mar 16, 2009
3,434
Shottingham
Thought I'd post in this thread instead of making a new thread...
I know that the Ibiza Mk3 exhaust is a straight fit for the Mk2, and would be my preferred choice but cannot find one anywhere for a decent price.
So my question is, do the exhausts from the Golf Mk2 or 3 fit on the Ibiza easily? There's loads on ebay, really cheap aswell......
elcristoff
Cupra Sport ****yeah!
Apr 8, 2009
167
Portsmouth
The mk3 Ibiza exhaust isn't a straight fit, it has a 2.5" diamiter as it was originally designed for a turbo, so a reducer to fit the 2.25" mk2 manifold is required.
Mine fits perfect, with all 3 brackets holding it up and no knocking/ vibrating. It has melted the bumper, just a little bit, but it now looks like it has been merged into it, so it looks pimp imo ;)
abhardwaj1990
Mar 16, 2009
3,434
Shottingham
Oh yh I know you need a reducer, but that's the case for all exhausts going on my 1.4. Getting desperate for a zorst now, hence asking if golf mk2 exhausts are easy to fit
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Mk2 golf is a no, a mk3 one might with 'persuasion' although i don't know of one on a MK2 off the top of my head.
The problem part with the MK2 is where it goes up and over the back axle and I don't know if the golf has this little quirk.
ibiza_95
1.8T MK2 Conversion
go have a look in the mk3 section for eople that have just bought a new exhaust and ask them if they still have their old one... put an ad in the wanted section...
i got offers within a day for mk3 exhausts, and got one for 60 quid posted which for a full system is nothing
if a mk1 clio exhaust fits an ibiza id be VERY suprised
back box only here for 30 quid:
http://www.seatcupra.net/forums/showthread.php?t=270171&highlight=exhaust
i have a centre section anyone can have for free if you collect it from wakefield
