can anyone tell me where the elbow in forges 5 piece silicone boost hose kit goes? I've sussed out the other 4 and just unsure of the 90 deg elbow's location. (is it under the bonnet or inside the wing with the IC piping?) cheers guys for any help.
Yeas as above.....You'll prob need to undo the 4 bolts and take both the half moon clamps off to fit it but its not a hard job![]()
What are these 4 bolts and half moon clips? The oem elbow is attached using jubilles either end.
Is it possible to undo one of the two metal pipes it connects in between to give more room when fitting?
the dump is up sidedown its not good for the turbo (beckpressure)
