i think the fault is with the relay as the indicator light isnt flashing in the cluster,and the fact that when i put the indicator off it keeps clicking but faster,like it would if a bulb was out.cheers
We sell loads of hazard switches, really common fault as the relay is built into it.
Two sizes depending on age of car - one will slip out easily, the other needs the radio removed to get at it from behind
Do you have cruise control? When my indicator stalk failed, it also made my cruise control not work properly (as well as giving me the noise you've described), when I slid the switch over to the left to increase speed it would increase speed but then not hold it. If you've got similar cruise problems then it could be your indicator stalk, if that seems fine then maybe start with a new hazard switch, it's much cheaper.
this is one of the last of the mk1 shape,ie 2005,i went to vw today to look at the mk4 golf one and mine is larger.how much are the switches and are they generally stocked??
thanks for the help,are these the easy to remove switches too?how do they come out?
