stalling in low revs
Jul 4, 2007
1,674
bristol
got vagcom it shows nothing apart from a lamba sensor i relaced both lamba sensors and it always pops up lamba sensor proformace too low which sucks. im going to do a log later see whats happening
May 25, 2008
2,400
cambs
maf? these some times throw rouge codes up ! it did with mine vag com kept stating lambda sensor bank 1 so i changed these twice at >£100 a pop then a mate swapped his maf with mine and hey presto no faults! IT doesn't always state maf probs but these are sensitive to knocks/ vibration
Jul 4, 2007
1,674
bristol
cheers tom im going to do some single maf readings when i get a chance. havent got anyone close to me to plug thier maf in unless anyone out thiers near bmouth.
Jul 4, 2007
1,674
bristol
ive had the dump valve off the other day and regreased. also the revs seem to idle funny when going slow from third to second. wiered
Jan 8, 2007
2,958
Wiltshire
Normally this sort of thing is caused by a small boost leak, DV sticking or MAF too close to the DV return (but with Forge TIP you should be fine assuming it's for an Ibiza and not a Golf)
Backdraft also suggested a possible injector leak as a possible cause when I had similar issues (mine was a bad seal on the TIP)
