Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
got vagcom it shows nothing apart from a lamba sensor i relaced both lamba sensors and it always pops up lamba sensor proformace too low which sucks. im going to do a log later see whats happening
maf? these some times throw rouge codes up ! it did with mine vag com kept stating lambda sensor bank 1 so i changed these twice at >£100 a pop then a mate swapped his maf with mine and hey presto no faults! IT doesn't always state maf probs but these are sensitive to knocks/ vibration
cheers tom im going to do some single maf readings when i get a chance. havent got anyone close to me to plug thier maf in unless anyone out thiers near bmouth.
Normally this sort of thing is caused by a small boost leak, DV sticking or MAF too close to the DV return (but with Forge TIP you should be fine assuming it's for an Ibiza and not a Golf)
Backdraft also suggested a possible injector leak as a possible cause when I had similar issues (mine was a bad seal on the TIP)
