Technically they could. Otherwise a trampoline would be pointless
drop a solid object on one from a measured 6ft height and £10 says it jumps up but a lot less than the starting height
This is almost as bad as my mate insisting that pool balls come of the cushions faster than when they hit them... took me ages to convince him that thats not possible and that if it was if you put two cushions close enough a ball would never stop... you cant make energy out of nothing.
constant enertia so if you wanged the pool ball really hard around the table it would just keep going and get faster and faster and faster and faster .....
maybe you should have told him about newtons law .. every action has an equal and oposite reaction .... im still baffled as to how they can be selling these surely its false advertising ???
as some one pointed out would be counter acted by the alternator creating drag lol
You start from actually on the trampoline, so the stretch of the material must create some energy to spring you higher
This has gone really off topic lol
Wouldn't that mean the car would run horribly lean as theres more air going in and no extra fuel??
Admitadly in real life, the ball wouldnt get faster and faster, however in a vacuum, with a perfectly smooth resistant free surface, it could
If there is a bit of spring in the cushion, then I guess it could come off the cushion a tiny bit faster than it did when it hit, however it wouldnt keep going because of the resistance from the table cloth
