right,will nip out and do them now!
The lambda......can it be changed easy enough yourself or is it a garage job?
Easy. Just one plug and it just screws into the exhaust.
aaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhh!!!! quit it
Group A: '031 Group B: '032 Group C: '033
Lambda Sensor Lambda Sensor Lambda (add.) Lambda (mult.) Bank 1 Bank 1 Voltage
TIME Current Value Specified Value Self-Adaptation Self-Adaptation Lambda Control of Oxygen Sensors
STAMP STAMP % % STAMP % V
0.3 0.969 1 0.6 0 -5.5 0.01 0.8 1.44
1.21 0.977 1 1.51 0 -5.5 0.91 0 1.32
2.11 0.938 0.945 2.41 0 -5.5 1.81 -1.6 1.38
3.02 0.945 0.945 3.32 0 -5.5 2.72 -1.6 1.3
3.92 0.93 0.938 4.22 0 -5.5 3.62 -2.3 1.3
4.84 0.891 0.875 5.14 0 -5.5 4.54 -3.9 1.1
5.74 0.828 0.821 6.05 0 -5.5 5.43 -3.1 0.88
6.65 0.766 0.782 6.95 0 -4.7 6.35 -0.8 0.36
7.55 0.75 0.782 7.85 0 -4.7 7.24 0 0.24
hmmmh with decat usually.. 100 cel shouldnt throw eml.
id rather have the fault sorted than map it out tbh. its running rich which is causing the light, if you map it out then how will you know if its fixed?
i wouldnt mate tbh.
Any place in particular to get a new lambda mate,and it's the front one i need is it,there are two arent there![]()
