Latest logs,please take a look
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
right,will nip out and do them now!
The lambda......can it be changed easy enough yourself or is it a garage job?
diy, as long as it isnt seized in or wires stripped...
make sure the cat is cold tho eh??
yeah log them and post up mate... be quick as i WILL beat damo to the next post... oh yes:p:whistle:
Jul 29, 2006
723
cumbria
www.facebook.com
right guys here we go:blink:
Code:
Group A:	'031	Group B:	'032	Group C:	'033
	Lambda Sensor	Lambda Sensor		Lambda (add.)	Lambda (mult.)		Bank 1	Bank 1 Voltage
TIME	Current Value	Specified Value	Self-Adaptation	Self-Adaptation	Lambda Control	of Oxygen Sensors
STAMP			STAMP	 %	 %	STAMP	 %	 V
0.3	0.969	1	0.6	0	-5.5	0.01	0.8	1.44
1.21	0.977	1	1.51	0	-5.5	0.91	0	1.32
2.11	0.938	0.945	2.41	0	-5.5	1.81	-1.6	1.38
3.02	0.945	0.945	3.32	0	-5.5	2.72	-1.6	1.3
3.92	0.93	0.938	4.22	0	-5.5	3.62	-2.3	1.3
4.84	0.891	0.875	5.14	0	-5.5	4.54	-3.9	1.1
5.74	0.828	0.821	6.05	0	-5.5	5.43	-3.1	0.88
6.65	0.766	0.782	6.95	0	-4.7	6.35	-0.8	0.36
7.55	0.75	0.782	7.85	0	-4.7	7.24	0	0.24
Now guys if i am having this lambda sensor mapped out do i still need to get a new one?
james walker
May 24, 2007
5,121
retford notts
hmmmh with decat usually.. 100 cel shouldnt throw eml.
id rather have the fault sorted than map it out tbh. its running rich which is causing the light, if you map it out then how will you know if its fixed?
i wouldnt mate tbh.
Jul 29, 2006
723
cumbria
www.facebook.com
i wouldnt mate tbh.
That's fine mate,like i said i'm pretty clueless round cars and was just going with recommendations
james walker
May 24, 2007
5,121
retford notts
learning curve matey...id sort the fuelling out first, then look at stage 2 mapping.
so narrowed down to dodgy lambda, although the lambda spec/actual looks okay to me... just the fuel trims again on 032. running quite rich. or the mapping... id post to will and ask if it could be overfuelling on stage 1 with dp and cat?
any other symptoms you noticed on general running
james walker
May 24, 2007
5,121
retford notts
possibly... but rich will feel different.
what id do mate...
1.reset ecu.
2. re align throttle body (clear the fault code first)
3. 2 tanks of bp with octane booster in
4. new plugs
relog then, see what the cfs are doing.
if still high, look at lambda first then the dp and cat id say
james walker
May 24, 2007
5,121
retford notts
Any place in particular to get a new lambda mate,and it's the front one i need is it,there are two arent there:confused::blink::whistle:
yeah 2 sensors... pre cat is one you need i think.
try ebay mate, theres some bosch oem on htere, 75 quid i think
can get them cheaper but id stick to oem.
also, have a check at the sensor first, make sure it isnt loose or wires stripped or anything before you go buying a new one
