I want to hook up a reverse camera and want to connect it to the reverse light wiring so the camera only comes on when in reverse. Any ideas which cables are for the reverse lights ?
sounds daft but i did the same and ended up putting it onto a manual switch by the handbrake instead instead
can use it as a rear view mirror then
Take a signal to a relay from the reversing light switch on the top of the gearbox.
that would be great mate, thanksi can trace the wire from the lights back through the car if its any help to you, as i have my interior removed
sounds hard to get to\find. Would wiring it to the reverse light wiring in the boot do the same thing ?
can you test it with a standard feed of a known source, at least it's a known quantiity then
i rigged mine up and tested it all off a battery to make sure everything was clean and had the video output plumbed to the tv to see if it worked ok too
might be a dodgy lead/camera possibly or longshot checked the rca output is in the right place ? mine has several inputs and two em were labelled wrong way round mind
leads are brand new. Its defo in the right input on my headunit, its just one brown RCA input that says Reverse Camera.
hence me askingmine had 3 yellow and aux / rev camera were mixed up
i would tap a 12v battery supply and test all is working firstly
2 seconds I'll take a look. what colour do you think the reverse wiring is?
