R4cup
Beef NO Burger
Jul 28, 2006
1,749
In the garage
My car has been suffering with over boosting issues for the past few months so i decided to turn the little screw on the N75 to see if that would cure it which actually made it worse as the car will not boost over 0.5bar.
Now that i have replace N75 my car is peaking at 1.6:wtf:
Since ive noticed this i have been taking it easy as i dont want the litle ko3 to go pop.
Why is this? anyone........
sounds about right if it is in higher gears what map is it?
seems a bit high for stage 1 . i didnt even notice there was a screw on n75 . owell mate new n75 should be better iv gone through 2 im on 3rd now . lol
thats what i thought as my las map was aggresive and only made a bar
anyone heard much about zender clamping the Map sensor?
as EZ Tutty(user on here) has solved his overboosting via this........
my stage 1 runs 25psi (26psi on odd occassion) or at least it did run that until my boost problem appeared over last few months.
when i first put my boost gauge on it was peeking at 25 psi but it only peeks at 22to20psi! and thats only a stage 1 custom code map!
