hoggy90
Full time sexaholic
Nov 14, 2009
689
Scotland
Just asking as im looking to do a few bits and bobs to mine when i get it and was wondering what you have done and what kind of bhp your spitting out?
I've changed my air filter.
Picks up a bit quicker. No real major gains though.
A remap might be the option your looking for.
Ben
yeh im getting a new air filter and a remap...was wondering what kind of gains id expect to see?
oh and im looking at a leon at the mo for 2.5k but has done 110k miles....should i go for it or not? the miles shouldnt matter too much on a diesel?
Mines just kit 106k and runs sweet as a nut. These engines are bomb proof if well maintained.
Filter and map should see 145 bhp, which should give you a very noticeable difference.
Maybe get a new engine mount and TIP (if you can find one)
can you explain what these are mate?lol and what they do :lol::shrug:
Remap - Serial port software tuning. Changes your fuel mapping to unleash power by removing flat spots.
Filter - Air filter, can be a new panel or an open cone filter.
TIP - Turbo intake pipe, goes between the air box/MAF and the turbo. Can collapse when car gets remapped, so a reinforced silicone one is a good idea.
Engine mount - Stiffens up the mounts of the engine, allowing it less give on take off, improving traction.
I hope this helps...
Ben
You dont have to worry about changing the TIP on a tdi as it comes with a plastic one, some come with metal, or you can upgrade to metal, soon i weill be getting a full TIP in blue from SFS ;) You only have to worry about a collapsing TIP on a 1.8t petrol ;)
Ben
i thought this only happened to the 1.8t 225 :confused:
how easy are engine mounts to change? are there any engine stabilisers? my engine is quite wobbly, especially on the passengers side. What bout the pipe from the intercooler up?
ive had a AMD remap , filter and straight through de-cat system which im on about 150 there abouts and just about to order up 130/150 manifold , forge egr replacement pipe , forgemap sensor, custom FMIC and bigger injectors which should see me in the 170s im hoping
hope that helps
