May 22, 2009
786
South Wales
i have just fitted a decat/ full exhaust to my pd 130 ibiza and having a problem with it making a loud noise! i have looked under neath and the car is too low and the pipe is rattling against the top of the exhaust path and the bracket that holds brake pipe on the axle!
the problem could be solved if i ground down the bracket but there is a hole in it and i am wondering what that hole is for and if i actually need it! i wasnt sure whether it was for an anti roll bar or something!
does anyone kno if there is anything else i can do without highering the car on the coilovers. it is all the way down at the momment with the adjusters out, but it looks go so wanna avoid it!
cheers
na the bracket i want to grind down is on the rear axle which holds the brake pipe on, there is just another hole on the bracket and i am not sure wat it is for! it is where the exhaust rises over the axles!
any ideas?
i had the same problem with mine, just undo the exhaust clamps and jack the exhaust up a bit then retighten the clamps it should give you some more clearance.
hope this helps.
that is stop on! cheers mate,1 i am going to grind the bracket off i think, loosen the whole system and spend some time sorting it out. Oh, and have no one in the back of the car lol!! saves me rising it up!
I also have this problem when 1 or more persons sit in the back! So all you need to do to fix this is cut the bracket that sits above the rear axle still a bit confused? :confused:
na, thats fine, i was just unsure wat is does! i want to fit an anti roll bar eventually and i dont want to cut anything then find out i need the bracket.
cheers tho!
My adjuster cups are out, so there probably no room for it to rattle anyways lol. It does occaisonally, but only when pulling away with revs below 1k.
Right this is a pic of the piece that is rattling on my exhaust! Sorry for the poor quality pic was pretty dark
Can anyone think what i could do to prevent this knocking?
should this rattling really be happening atall on such a highly priced exhaust it should fit perfect not be hitting things,i would say maybe the exhaust was fitted poorly but as its happened to quite a thew it must be a bad design paying all that money for a supposebly quality exhaust for it to then rattle on a bracket just says bad design to me unless milltek advise you cut the bracket off.
My exhaust fit perfectly, Alex. I did take a little "tweeking" to sit properly, but its the same thing with any exhaust (standard or uprated).
I'd say its a fitting issue and just needs adjusting.
Cant remember how close the bracket was on mine but it has never ever rattled from day one :)
I did fit it on a ramp though ;)
Go and get it re-fitted correctly! I had the same problem on old car until I took it to a VAG specialist who said it wasn't fitted correctly :)
