D1SHABBA
318
i have noticed a couple of times this week when i start the car in the morning before warming up the light on the left starts to flash and beep beep i have to switch off the engine a couple of times before it goes off.
anybody had this problem and what have you done
Check the prongs of the sensor in the coolant reservoir. Usually get a bit scaley and need scraping off. In severe cases they need replacing.
hmmm! il have to leave that for a dry day then if that ever bludy comes now......:shrug:
Scraping the prongs lasts for a year then it will beep the next year. By then you should replace the reservoir they are very cheap about a tenner from dealers.
Alot less hassle in the long run i think.
Probably not best to always ignore it. I did, and mine was infact leaking, from the radiator and the aux coolant pump...
