As above chap's, i'll post this in the vag-com section aswell but if there are any techie types in here that can help it would be much appriciated.
I noticed a few weeks ago that the LCR didn't feel quite right, spool up seems to take longer and the boost doesn't seem to peak as it used to. My trip computer and average MPG all re-set themselves every time the key is removed from the ignition? MrDave got Vag-Com on it for me and it threw this up
16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
Possible Symptoms
Power Loss
Possible Causes
Camshaft Adjustment Valve 1 (N205) faulty
Fuel Pump Relay (J17) faulty
Possible Solutions
Check Camshaft Adjustment Valve 1 (N205)
Check Fuel Pump Relay (J17)
Special Notes
When found in Engine: 4.0l W8
Check TPL 2010059(RoW)
Check/Replace Oil Sieve in Timing Case (Camshaft Adjuster)
We cleared the fault and it was fine for about two weeks, i now have the feeling it's back again
It's probably worth mentioning it was two very cold day's this has happend, could it just be the cold weather messing around with the ECU? As my work's van has played up a bit with the engine management light lately aswell?!
Possible Symptoms
Power Loss
Possible Causes
Possible Solutions
Special Notes
