I Love Water Leaks!!!
Al_G
449
Manchester
NOT!!!
I seemed to have developed a nasty one above my accelerator pedal!
Checked under the scuttle panel and everything looks solid and free of leaves, dirt etc.
One think I did notice is that the seal around the loom housing felt a bit wet. Is this a common place for a leak?
Oddly enough I can only feel damp once the car has been on a run.
Anyone else got any leaks they'd like to declare lol!?
vee_dub_modder
Volkswagen racing tech-pt
Feb 19, 2008
406
Midlands
NOT!!!
door/Window regulator seal... foam ****** seal dies. pull it off and use sealer to re-fit. -- may also soak up your carpet a bit?? can usually see water around the seals having said that mind...:think:
Al_G
449
Manchester
I wondered about this but the carpet around the door is dry. The leak (wettest part of the carpet) seems to be coming from top right of the dash - above the relays behind the steering column trim...Surely this wouldnt be the case if the door was leaking?
BlackLeon
65
Brighton
NOT!!!
YES! me too. couldnt find where it was coming from for weeks so i went to a car wash today (my carpets couldnt get any wetter!) and quickly got in the back and stared at my doors... caught me by suprise it was pouring in when the washer was cleaning the front end and no where else, so not scutter panel and not door sills! So the water is coming in when it's wet from the spray from the car infront! But what hole could have formed that leads to the small golf ball size hole above the pedals???!!
BlackLeon
65
Brighton
also, check the carpet behind drivers seat, that's soaked too as the water runs along the side of the car under the carpet... grr. I've stuffed a demisting pad in the hole, had it there for a week or so, it is actually stopping 90% of the water coming in but once summer comes it HAS to be sorted!
Al_G
449
Manchester
So it was pouring in from the bulk head somewhere?
Al_G
449
Manchester
Everywhere else is dry - The water was dripping from the carpet above the ignition relay last week causing the car to break down :(
Al_G
449
Manchester
So where was the hole fella?
NI3K
58
i have the same thing, finding it hard to tell if sealing up under scuttle panel has worked or not as theres not been much rain
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,439
Most likely at work
all four of my doors had leaky seals. had to attack the seals more than once with silcon sealant which worked for a while. now iv bought some heavy duty sealant and i hope to reseal my doors again when i can be arsed... apart from that i suspected a leak from my pollen filter, which turned out to be ok for once.
NI3K
58
i think the door seals was an easy fix at least you could tell that it was sealed up properly i just hate the leak above the pedals as cant find where its coming from or even if its still there since being sealed up. had a quote from seat for £300 plus VAT for the pedal leak fix!
Al_G
449
Manchester
lol does that mean they know where its coming from?
have you checked/opened the wiring loom box next to the bonnet release cable under the scuttle panel?
NI3K
58
they said its a common problem, from bulkhead seal. i sealed around that wiring loom box and bonnet release cable in my attempts to solve but still dont know if successful yet or not
Al_G
449
Manchester
hmmmm bulkhead seal - wonder which seal they are refering to?
Would they not tell you without you coughing up £300 lol?
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
ive done all this and sealed the fxxk out of every thing and this morn steamed up in side iam getting sick off this car now seat shud do it for free its there fxxk up.iam giving it 1 last go and if it ant sealed this time its going asap.
sunilbass
278
lesta
yep same here, all the windows are fogged up, got some rain x anti fog, i need to give that a try!
