brake upgrade
dimond
has anyone done a brake upgrade ive upgraded to the corrado g60 280mm brakes but wouldnt mind some 2 or 4 pot calipers has anyone done this and what calipers etc did you use?
godzuki
Mk2 cupra & golf mk2 20vt
Sep 11, 2006
231
Newcastle upon tyne
With your G60 hubs the easiest upgrade would be to go for mk3 ibiza cupra R brembo 4 pots and the 305mm 4 stud discs
Easiest as they will bolt straight on but not the cheapest :-(
Is your master cylinder standard or a 23mm g60 item? i say this as you'll need a large M/C if your going to push more fluid!
dimond
its standard but i can get hold of one cheap enough il have a look at the cupra 4 pots cheers
pro7dave
Will the 305mms and four pots go behind a 16" wheel? There not stockers, there OZ Superleggaras. There looks to be plenty of room behind the spokes.
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Nope, think superleggras even in 17" need a 5mm spacer to allow room for 305mm & brembos
Badger 5 done a thread on what alloys will fit 305mm and if not how much spacing is needed: Click Here!
dimond
what alloys will you be running? Don't think the Brembos will sit behind you ATS Cups
im thinking of getting some new rims soon anyway im not in a hurry to get the brakes just wanted to kno which 1s 2 get
