dimond
has anyone done a brake upgrade ive upgraded to the corrado g60 280mm brakes but wouldnt mind some 2 or 4 pot calipers has anyone done this and what calipers etc did you use?
With your G60 hubs the easiest upgrade would be to go for mk3 ibiza cupra R brembo 4 pots and the 305mm 4 stud discs
Easiest as they will bolt straight on but not the cheapest :-(
Is your master cylinder standard or a 23mm g60 item? i say this as you'll need a large M/C if your going to push more fluid!
its standard but i can get hold of one cheap enough il have a look at the cupra 4 pots cheers
Will the 305mms and four pots go behind a 16" wheel? There not stockers, there OZ Superleggaras. There looks to be plenty of room behind the spokes.
Nope, think superleggras even in 17" need a 5mm spacer to allow room for 305mm & brembos
Badger 5 done a thread on what alloys will fit 305mm and if not how much spacing is needed: Click Here!
what alloys will you be running? Don't think the Brembos will sit behind you ATS Cups
im thinking of getting some new rims soon anyway im not in a hurry to get the brakes just wanted to kno which 1s 2 get
