Some people have cut them down to the end of the fat bit also, looks just like a 2000 aerial.
If my experience is anything to go by your reception will be pretty awful after fitting the C3 aerial, but as you've ordered the Milltek I doubt you'll be able to hear the radio anyway! :D
Think I'm going to ditch my aerial and go back to standard (if I can find it) cos I miss listening to the local pirate radio station. Can't pick it up anymore. In fact I can only pick up 3 or 4 stations since fitting it!
C5 aerial mate. Milltek is lovely and quiet inside and its resonated too so not any louder than standard. I had one on my last Cupra.
hope this works... as you can see its not abnormally short. just gives the impression that someone at seat thought "hmm... i could make this look a bit better!!"
Does anyone have a part number for the C2 Aerial? I went into a Citroen dealer around the corner who didn't know what I was on about and the car on the forecourt had a long aerial but that was a base model I think. I presume that only a certain C2 had this aerial, perhaps the VTS?
I had the same problem, cant remember the part number but it is also fitted to the big estate model with all the toys - only found it in the end because there was one in the showroom :lol:
If you are not using an OEM stereo then you will NEED to buy a booster. They cost about £5 from ebay and are easy to wire up, this made my signal MUCH better. Could barely pick anything up before and now only loss signal in some spots.
